[ANSYS Meshing] 3D meshing
Old   June 23, 2016, 00:46
Default 3D meshing
monty86 is on a distinguished road
Hello everyone,
I am beginner in Ansys fluent. I want do 3D stirred tank simulation. For that I developed the geometry with primitives in ansys design modeller. Now in meshing I want to do a structured meshing & instead of default meshing I want to mesh each geometry part separately for better control. Can anyone help me how to do separate meshing for each part with different control? I want to also know about how to start the ICEM as in Ansys fluent i am not able to see it. Please help me out in this as I have stuck here for long time.
monty86 is offline   Reply With Quote
Old   June 23, 2016, 01:42
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
ANSYS Meshing:
1. Slice your parts
2. Method : Map
3. Set sizes on your curves and done
To open ICEM CFD, you can do it directly from start menu or from workbench.
Far is offline   Reply With Quote
Old   June 23, 2016, 02:02
Thanks Far.
From workbench where is the location to start the ICEM? Can I do this separate meshing in ansys Modeller also? as I am running out of time so to learn ICEM may require extra time.
Thanks in advance
Old   June 23, 2016, 02:09
Far
Sijal
can you share your geometry. So that we can suggest you method.
Another options is to use tetra + prsim mesh. and it should also give you good results.
Old   June 23, 2016, 02:36
Please find attached geometry file for my case.
Please also send me your e-mail ID so i can share you it on there.
currently my guide told me to do structure mesh & divide geometry near impellers into more parts for better control.
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
