September 19, 2016, 07:20 |
Match Edge Spacing Error
Rep Power: 9 |
Hello everyone,
this small problem is driving me nuts. I simply want to match edge spacing between two edges. I match the spacing of the left to the one on the right. I am also copying this spacing to all other parallel edges. However, it does not work on some edges - or, it only works partially, as can be seen in the attached pictures. Does someone have a clue why it is like this? I already tried linking the spacing, just typing in the desired spacing, changing the bunching to something else and then trying bigeometric again. Thanks a lot in advance. Greetings, stuffen |
September 19, 2016, 08:11 |
Rep Power: 9 |
I resolved the second picture. Apparently the edge was not properly assigned to the surface.
However, the issue seen in the first picture is still unresolved. |
September 20, 2016, 08:39 |
Rep Power: 9 |
Nobody any clue? This is really messing up the quality of my mesh
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
