[ANSYS Meshing] ANSYS Mesher cann't update geometry from parameter set
Like Tree1Likes
  • 1 Post By Kapi
Old   October 12, 2016, 06:22
Lightbulb ANSYS Mesher cann't update geometry from parameter set
Moustafa Raafat Shousha
M.Shousha is on a distinguished road
Dear All,
I'm a new user in ansys fluent and have a problem in updating my mesh. I work on a backward facing step model as seen in the figure
(Please Follow numbers on figure below)
[1.]
I've created a parameter table and chosen 7 parameters to study;
Geometric parameter from design modeler (Yc & Xc)
Velocity magnitude from fluent (Vin)
Fluid Properties from fluent (Rho, Cp, K and Mu)
and set Reynlod's numebr as an output parameter from CFD-Post (Re)
[2.]
After solving, i'v found that Fluent read Vin which I've supplied in parameter set
[3.]
unfortunately ANSYS Mesher can't read geometric values supplied by parameter set, while DM read them correctly. This can be seen if you compared the location of the circle in DM and Mesher.....
- The final solution gives me results for the wrong location as a result of the mesher update problem
- ansys didn't show any warnings or error messages
I tried to reset ansys mesher and rebuild my mesh again but nothing changed.
_______________
I've checked the source file of geometry from Mesher
and opened it separately, it showed the correct geometry but the mesher still show the wrong one
I truely appreciate your help... Thank you
M.Shousha is offline   Reply With Quote
Old   October 12, 2016, 19:10
Default Hello There
Khaled Ahmad
kh.aa is on a distinguished road
إقفل كدة الجهاز وإفتحه !!
kh.aa is offline   Reply With Quote
Old   October 12, 2016, 19:18
Kapi is on a distinguished road
kh.aa,
If you want to answer a question, use English as it is not preferred but only used language in this forum!
kh.aa likes this.
Kapi is offline   Reply With Quote
Old   October 14, 2016, 05:01
Paritosh Vasava
vasava will become famous soon enough
First of all, you have explained your problem nicely.
This is bit tricky to answer without having the actual setup. It would be nice, if you can upload it somewhere. If you cant then can you post picture of the parameter setup in DM and the screenshot of the whole project from workbench file?
Also, I see in your picture that you have only one design point. Have you tried adding more design points or you just modify values in single design points and record results?
vasava is offline   Reply With Quote
Old   November 25, 2016, 05:11
Thank you for you reply Dr. Vasava
Please find the archived ansys, as you advised;
https://drive.google.com/open?id=0B_...3FQa0NVWlU0TmM
Actually I'm working on 576 design points and divided them into 32 ansys files with 18 design points each.
(It's a huge number of design points to study that's why i'm planning to correlate my parameters later, but now i'm interested in assuring that parameter set works fine and i can export my results from each DP without creating a seperate ansys file for each one)
The Mesh Update problem appears when worked on the 18-DPs file, that's why i've created the single design point ansys file as a troubleshooting procedure.
I really appreciate your help, Thanks.
Geometry from autocad to ansys catmelon ANSYS 0 May 20, 2016 21:28
ANSYS 15 Geometry for 14.5 shubham.root ANSYS 0 November 15, 2014 19:04
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 17:41
[ICEM] set workbench parameter in icem cfd script nnvoro ANSYS Meshing & Geometry 2 April 28, 2013 14:23
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
