[DesignModeler] How can I split the edges along the airfoil?
Like Tree2Likes
  • 1 Post By oozcan
  • 1 Post By sarangdalne
Old   November 30, 2016, 12:48
Default How can I split the edges along the airfoil?
aero_cfd is on a distinguished road
I would like to be able to split the edges of the airfoil as shown in the picture attached, but without having to make that line projection which mess up the mesh, is there a way to do it then create a named section for it for the upper and lower surface ?
Thank you !
aero_cfd is offline   Reply With Quote
Old   December 2, 2016, 07:24
Onur Özcan
oozcan is on a distinguished road
you can select ''merge'' in DesignModeler.Thus, all edges will be removed. Dont forget that when you click merge, boundary merge zone should be ''yes''
aero_cfd likes this.
oozcan is offline   Reply With Quote
Old   December 2, 2016, 18:02
Sarang Dalne
sarangdalne is on a distinguished road
You can split the edge in meshing application using virtual edge split. You don't need to split it in DM. This what you will need to do:
Once in meshing application:
1. Click on the Model object. In the toolbar you click the Virtual Topology button.
2. Select the edge which you want to split. In the toolbar select the option "Split edge at"
You can also change the ratio of edge split by holding down F4 button and selecting the vertex splitting the original edge and then slide it along the edge using left mouse button click.
Hope this helps you. Good luck.
sarangdalne is offline   Reply With Quote
Old   December 6, 2016, 05:59
Thanks a lot, haven't tried this one, but it is possible to do it in DM as well , just by going to concept>Split edge .
airfoil 2d, edge, mesh 2d, split
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
