[ANSYS Meshing] Mesh Matching at interface between two parts |
March 12, 2017, 11:07 |
Bharath N
Rep Power: 10 |
I'm constructing mesh in ANSYS 15.0, I have to mesh the two parts (see attachments), I want to simulate pitching and plunging motion for that i want Fluid region surrounding the plate to move with the plate. When I mesh the meshes at interface between two parts are not matching i.e., the nodes aren't connecting. I have tried to merge the two parts by creating a new part but having single part i can't move the other part( motion of fluid region) If i go with the old not connected mesh I'm getting divergence error. Is there any way I can fix this Issue? Please help me with this Thank you [ATTACH]sluid19.PNG[/ATTACH]MESH.PNG |
March 13, 2017, 07:48 |
Paritosh Vasava
Rep Power: 22 |
There are two ways to impose matching
Try and let us know how it goes. |
March 14, 2017, 01:51 |
Paritosh Vasava
Rep Power: 22 |
Without seeing your case setup its difficult to pass comment about why this is happening. But here is what I think:
1. You could be too early in your simulation time to make observations. I mean for such a system I would wait for at least 10-15 rotations before I see any periodic behavior. 2. The interface is not set correctly. 3. The rotation (axis, center etc) is not set correctly. |
March 15, 2017, 05:35 |
Bharath N
Rep Power: 10 |
Thank you Sir for your suggestions.
My case file isn't uploading here.. can you give me your email id so that I can mail you Problems are 1. I can see contours over interface zone 2. dynamic mesh failed negative cell volume detected error I think my geometry and meshing might be wrong Can you guide me with Geometry and mesh generation Please help me with this sir, I have no one to guide me. Thank you |
March 10, 2018, 09:15 |
Emanuele Spinosa
Rep Power: 11 |
I also tried Shared Topologu and it works. However, with Shared Topology I have some problems in setting up the interfaces with Ansys CFX because the Named Selection set in Design Modeler are not preserved in Ansys CFX. How can I solve this problem?
March 10, 2018, 11:27 |
Emanuele Spinosa
Rep Power: 11 |
March 10, 2018, 11:39 |
#10 | |
Emanuele Spinosa
Rep Power: 11 |
I think it's better to keep the parts separated and then using the MATCH mesh options. Anyone know how to use it properly? This could be USEFUL for MANY PEOPLE, I think ... ... |
March 12, 2018, 03:24 |
#12 |
Gert-Jan
Rep Power: 27 |
I never have problems with interfaces in CFX.
Do you have 2 different volumes in CFX-Pre? Did you look for the surfaces in between when clicking on the button with the three dots? "..." If the surfaces are not in that list, then your setup is wrong. Either in CAD or in the meshing. Probably your way of thinking is wrong, leading to an inappropriate setup. I would suggest to do more tutorials where interfaces are required. |
March 12, 2018, 03:29 |
#13 |
Emanuele Spinosa
Rep Power: 11 |
Hi Jan, until now I set up my interfaces manually having given them a name (Named Selection). Probably this is not necessary, I just feel more confident doing like this ...
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
