[ICEM] Blocking: H-mesh inside O-grid
Like Tree6Likes
  • 1 Post By sindre
  • 1 Post By Far
  • 1 Post By sindre
  • 2 Post By sindre
  • 1 Post By bluebase
Old   January 20, 2014, 09:07
Default Blocking: H-mesh inside O-grid
Sindre
sindre is on a distinguished road
Hi all,
is it possible to create a H-mesh inside a O-grid in ICEM (ref figure below, trying to illustrate block setup)?
(I want to use this to mesh a rectangular cylinder (second figure).)
Best regards
Sindre
aero_head likes this.
sindre is offline   Reply With Quote
Old   January 20, 2014, 10:57
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
yes quit possible. just use blocking index and display the center rectangle and then split it as you like
sindre likes this.
Far is offline   Reply With Quote
Old   January 20, 2014, 11:07
Sindre
Thank you so much for responding, been working on this problem for a while. Can you please explain what you mean by using "blocking inside"? Do you mean that I can hide the surrounding blocks and then only split the center block?
Old   January 20, 2014, 12:01
Far
Sijal
sorry, i had to write index but typed inside. Yes just hide the blocking surrounding the rectangular block and proceed.
Old   January 20, 2014, 12:53
Sindre
That worked perfectly, as shown in the first figure
But this leaves me with another question:
Is it possible to create a Y-grid inside a O-grid (indicated by red lines on second figure)?
(((For information: I found the Index Control by right clicking the Blocking tab in the tree on the left side. User manual states that it is also possible to use the shortkey "i". )))
Old   January 20, 2014, 12:59
Far
Sijal
yes. That is done with ogrid. Just select two faces and you are done.
Old   January 20, 2014, 13:03
Sindre
I've been trying to do this in the same way, but it interrupts the surrounding blocks. Pictures displays the result.
Old   January 20, 2014, 13:28
Far
Sijal
first make yblock and afterwards oblock
Old   January 20, 2014, 13:44
Sindre
Do you know if it is possible to do it the other way around?
The reason why I'm asking is that I want to use the Y-block to create a mesh around a sharp corner, as shown in the first figure. That is, block 25, 27, 23 and 4 om the second figure.
Old   January 20, 2014, 13:56
Far
Sijal
just select two side face and you are done
Old   January 20, 2014, 15:13
Far
Sijal
Old   January 23, 2014, 09:30
Sindre
Thank you Sijal,
Your method worked out perfectly. The blocking index option was exactly what I've been searching for.
I've posted a couple of pictures below, showing the resulting mesh.
Sindre
Old   January 23, 2014, 09:42
Far
Sijal
It is unique blocking strategy. Great work
Old   May 16, 2014, 07:38
Sindre
After requests some more pictures are posted of block topology and generated mesh.
EDIT: This time of a square cylinder.
aerosaravanan and aero_head like this.
Old   June 16, 2015, 07:24
Tom
hoangtugugu is on a distinguished road
could you show me how to create y-grid around the corners of the rectangle in ICEM CFD?
hoangtugugu is offline   Reply With Quote
Old   June 30, 2015, 09:08
Siddana ravi Kumar
siddana2005 is on a distinguished road
I would like to practice this model. if u dont mind can i have it?
siddana2005 is offline   Reply With Quote
Old   March 18, 2017, 16:07
Ernesto
epc1 is on a distinguished road
Hello, could you elaborate more on this? i'm lost in this step.
I'm also trying to create a y block buy can not understand this step.
Thanks
epc1 is offline   Reply With Quote
Old   March 20, 2017, 03:55
Sebastian Engel
bluebase will become famous soon enough
Hello Ernesto,
have a look at the attached picture.
In the ogrid menu, use "add faces" to select the red-marked faces/edges in the picture. The use "add blocks" to selct blocks which are marked in light red in the picture.
Then you should come up with a blocking sindre asked for.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   March 21, 2017, 06:00
Ernesto
Originally Posted by bluebase View Post
Hello Ernesto,
With regards,
Sebastian
Attachment 54759
Thanks a lot Sebastian!
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
[Other] How to mesh the 1st grid point lakeat OpenFOAM Meshing & Mesh Conversion 1 October 8, 2007 07:13
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
