[ANSYS Meshing] Micro Composite Patch on Carbon Fibre Reinforced Ploymer |
April 10, 2017, 09:58 |
Nidish Narayanan
I want to design a geometry and subsequently use it to do a couple field analysis, static structural and transient analysis. I have a Micro Composite Patch(85*28*0.3 mm) that has a piezoelectric property which is glued on top of a Carbon Fibre Reinforced polymer beam(400*45*1 mm). I developed the model in MAPDL and tried to sweep mesh the two volumes.But one volume(CFRP) would not mesh. Please provide suggestions. |
April 19, 2017, 08:19 |
Paritosh Vasava
Rep Power: 22 |
Were you able to solve your problem with Ansys meshing?
April 19, 2017, 08:58 |
Nidish Narayanan
yes, I managed to solve it. But I still am looking into the problem of how to model a piezoelectric patch on a composite material . I have seen different videos on youtube, tutorials and all but not really helping.
composite, composite fibrte, coupled field., microfibre patch, piezoelectric |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
