[ANSYS Meshing] Error: "An allocaton was made with a negative.."
Old   May 23, 2017, 06:33
Default Error: "An allocaton was made with a negative.."
Alexander Spaett
Alex0815 is on a distinguished road
Hello everyone,
I tried meshing 2 completely different setups and got the same error both times. At first I thought it was just me doing sth wrong in the meshscript and just couldnt figure it out. Since I just couldnt find any solution i moved on to a very simple setup. Turns out: the EXACT same error message occured again. I wanna highlight that the requested length AS WELL AS the linenum was the same for both setups!
Message: An allocation was made with a negative length requested: -705425008 Filename:FEM_smooth.c Linenum:2399
Screenshot:
Meshscript 1:
! ----- Header ------ !
FINI                    ! exits all old scripts
/ CLEAR                     ! clears workspace
/ PREP7                    ! starts command interface
NACSINIT                 ! starts NACS interface
! ----- Definition of variables ------ !
elemMode = 'quadr'        ! Quadratic elements = good
! Definition of our Transducer element [Flat at first]
r_emfi = 20e-3                                       ! Radius of the EmFi [ = 20 mm]
h_emfi = 5e-4                                    ! Height of the EmFI [ = 0.5 mm -> Datasheets on EMFIT Site]
! Definition of the Reflector
r_reflector_i = 50e-3                       ! Inner Radius of the Reflector [ = 50 mm] -> Determined in the corresponding Bachelor Thesis
w_reflector = 2e-3                                     ! Thickness of the Reflector    [ = 2 mm ] -> Assumption
r_reflector_o = r_reflector_i + w_reflector     ! Outer Radius of the Reflector
! Air  region:
h_air_1 = 5e-4                    ! Height of the Air rectangle in the bottom  [ = 0.5 mm]
r_air_1 = 80e-3                    ! Outer Radius of the Air_bottom area [ = 120 mm]
h_air_2 = 100e-3                ! Height of the middle Air rectangle [ = 500 mm] [first iteration]
r_air_2 = 100e-3                ! Outer radius of the middle Air rectangle [ = 200 mm]
r_air_3 = r_reflector_i                ! Air in the reflector [ = 50 mm]
r_air_4_i = r_reflector_o            ! Air sourrunding the reflector
r_air_4_o = 100 e-3
h_air_4 = 100e-3
dx = 85e-6                    ! Meshsize (calculation: dx = c / (20*f) = 343 / (20 * 200000) = 85e-6 m ) [here: may Frequency = 200 kHz]
w_pml = 8*dx                ! Width of the pml region [Used for better results at the outer boundaries of the region]
tol  = dx/5
! ----- Create the geometries ------ !
! RECTNG , x_min , x_max , y_min , y_max -> rectangle from x_min , y_min to x_max , y_max
! CYL4, X_Center, Y_Center, R_1, Theta_1, R_2, Theta_2
! FIRST THE "Complicated" part of the air region [Cutting the whole into the rectangle]
RECTNG, 0, r_air_2, h_air_1 + h_air_2, h_air_1 + h_air_2 + h_air_4    ! Air Region 4 [Circular has to be substraced from it]
ASEL, s, area, , 1                                                      ! Select Air Region 4
CM, temp1, area
CYL4, 0, h_air_1 + h_air_2, 0, 90, r_reflector_o, 0               ! Air Region 4 [Ciruclar which has to be substracted from Rect.]
ASEL, s, area , ,2                            ! Select Air Region 4 [Circular Part]
CM,temp2, area
ALLSEL                                    ! Select everything [otherwise ASBA - Area substract Area does not work properly]
ASBA, temp1, temp2                            ! Substracting the inner Part of the AIR AREA to be able to glue and mesh
RECTNG, 0, r_emfi, 0, h_emfi                                         ! EMFI
RECTNG, r_emfi, r_air_1, 0, h_air_1                            ! Air Region 1
RECTNG, 0, r_air_2, h_air_1, h_air_1 + h_air_2                ! Air Region 2
CYL4, 0, h_air_1 + h_air_2, 0, 90, r_air_3, 0                ! Air Region 3 [Circular]
CYL4, 0, h_air_1 + h_air_2, r_reflector_i,90,  r_reflector_o, 0        ! Reflector
RECTNG, r_air_2, r_air_2 + w_PML, h_air_1, h_air_1 + h_air_2 + h_air_4    !PML REGION Right
RECTNG, 0, r_air_2 + w_PML,h_air_1 + h_air_2 + h_air_4, h_air_1 + h_air_2 + h_air_4 + w_PML !PML REGION Top
! ----- Connect the geometry ------ !
ASEL , all
AGLUE , all
! ----- Setup the mesh ------ !
LSEL , all            ! select all lines
LESIZE , all , dx        ! set the meshsize dx on all selected lines
MSHKEY ,2
SETELEMS , 'quadr' , elemMode
ASEL , all
AMESH , all
Meshscript 2:
h_emfi = 8e-5            ! Height of the EmFI [ = 0.5 mm -> Datasheets on EMFIT Site]
! Air  region:
h_air_1 = h_emfi        ! Height of the Air rectangle in the bottom  [ = Height of EMFI]
r_air_1 = 80e-3            ! Outer Radius of the Air_bottom area [ = 80 mm]
h_air_2 = 60e-3            ! Height of the middle Air rectangle [ = 60 mm] [first iteration]
r_air_2 = 100e-3        ! Outer radius of the middle Air rectangle [ = 100 mm]
h_air_3 = 20e-3            ! Height of the Air rectangle at the top [ = 20 mm]
r_air_3 = r_air_2        ! Radious of the Air rectangle at the top [100 mm]
! Mesh
dx = 80e-6
w_pml = 8*dx
tol  = dx/5
RECTNG, 0, r_air_2, h_air_1 + h_air_2, h_air_1 + h_air_2 + h_air_3
RECTNG, r_air_2, r_air_2 + w_PML, 0, h_air_1 + h_air_2 + h_air_3
RECTNG, 0, r_air_2 + w_PML, h_air_1 + h_air_2 + h_air_3, h_air_1 + h_air_2 + h_air_3+ w_PML
ASEL , all
AGLUE , all
MSHKEY ,2
ASEL , all
AMESH , all
I only posted them until meshing - since any further information is not relevant.
It would be really great if someone of you could help me out with this.
BR
Alex
Alex0815 is offline   Reply With Quote
Old   May 23, 2017, 08:38
Alexander Spaett
Possible solution:
> I resized the Air region since it was unnecesarilly large anyways [atleast for simulation 2]. Doing this seems to have fixed the problem.
> The Error Message still seems kinda strange to me. I'm not sure if this is actually a real solution or just made the regions go away where the problem accured.
Edit: Error Occured again at the same line [2399] after resizing it again
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 19:54
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
negative element volume (CFX-10.0) CFDworker CFX 8 September 27, 2011 18:16
negative volume encountered Maga CFX 2 October 7, 2009 17:31
