[ICEM] Which meshing tool can perform the surface-grid extrusion technique?
Old   May 31, 2017, 22:12
Post Which meshing tool can perform the surface-grid extrusion technique?
Yousef
yousefaz is on a distinguished road
I have recently come across a body-fitted meshing technique in the literature (van Hoof and Blocken, 2010) that I would like to adopt in my simulations. The technique is called the "surface-grid extrusion technique". Basically, it generates high quality hex grids for "very complex building and urban geometries", albeit labor and time intensive.
I have compiled the details of this method in the PDF link:
https://goo.gl/x93P01
My questions here is regarding the meshing tool. I am not sure which to use.
Studies adopting this technique have mentioned using GAMBIT. So far, I've been using ANSYS meshing for my simulations, so ideally I prefer to stick with ANSYS tools. However, I understand it may be a far stretch to expect this level of user control from ANSYS meshing.
The other option is ICEM, which I have not used in any extensive capacity. I suspect this technique is possible in ICEM, although I would appreciate if any ICEM users can confirm this.
Also, any specific pointers on how to adopt this method in ICEM are greatly appreciated.
Thanks.
yousefaz is offline   Reply With Quote
building, extrusion, icem, meshing, surface grid
[Gmsh] "Perhaps you have not exported the 3D elements?" j_moulton OpenFOAM Meshing & Mesh Conversion 14 October 6, 2022 21:58
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 8, 2016 23:10
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
thin extrusion meshing guillaume Main CFD Forum 0 October 27, 2008 18:36
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
