[DesignModeler] [DesignModeler] Pattern Function does not work,why?
Like Tree1Likes
  • 1 Post By Kapi
Old   June 11, 2017, 01:43
Question [DesignModeler] Pattern Function does not work,why?
LC
Vallence is on a distinguished road
Hi,everyone!
The following js code is a simple DesignModeler example.I want to body2 pattern around YAxis. But it does not work. How to set pattern axis?
var XYPlane = agb.GetXYPlane();
agb.SetActivePlane (XYPlane);
function planeSketchesOnly (p)
//Plane
p.Plane = agb.GetActivePlane();
p.Origin = p.Plane.GetOrigin();
p.XAxis = p.Plane.GetXAxis();
p.YAxis = p.Plane.GetYAxis();
//Sketch1
p.Sk1 = p.Plane.NewSketch();
p.Sk1.Name = "Sketch";
//Edges
with (p.Sk1)
a=10
b=20
h=20
p.Ln11 = Line(a,0,b,0);
p.Ln12 = Line(b,0,b,h);
p.Ln13 = Line(b,h,a,h);
p.Ln14 = Line(a,h,a,0);
edge1=p.Ln14;
//Sketch2
p.Sk2 = p.Plane.NewSketch();
p.Sk2.Name = "Sketch2";
//Edges
with (p.Sk2)
a=15
b=24
h=10
h0=12
p.Ln21 = Line(a,h0,b,h0);
p.Ln22 = Line(b,h0,b,h0+h);
p.Ln23 = Line(b,h0+h,a,h+h0);
p.Ln24 = Line(a,h+h0,a,h0);
//Dimensions and/or constraints
with (p.Plane)
p.Plane.EvalDimCons(); //Final evaluate of all dimensions and constraints in plane
return p;
} //End Plane JScript function: planeSketchesOnly
//Call Plane JScript function
var ps1 = planeSketchesOnly (new Object());
//BODY1
var MyRevolve1 = agb.Revolve(agc.Add,
ps1.Sk1,
ps1.YAxis,
agc.DirNormal,
360.0,
0.0,
agc.No,
0.0,
0.0);
agb.Regen();
//BODY2
var MyRevolve2 = agb.Revolve(agc.Frozen,
ps1.Sk2,
ps1.YAxis,
agc.DirNormal,
3.0,
0.0,
agc.No,
0.0,
0.0);
agb.Regen(); //To insure model validity
var MyPattern = ag.gui.CreatePattern();
MyPattern.Name="Pattern1";
ag.listview.ActivateItem("Pattern Type");
ag.listview.ItemValue = "Circular";
ag.listview.ActivateItem("Geometry");
agb.ClearSelections();
body1 = ag.fm.Body(1);
agb.AddSelect(agc.TypeBody, body1);
ag.listview.ItemValue = "Apply";
ag.listview.ActivateItem("Axis");
//ag.bodyPick;
ag.edgePick; //These two methods have been tried, No Pass!
ag.gui.SelectAll();
ag.listview.ActivateItem("FD2, Angle");
ag.listview.ItemValue = "Evently Spaced";
ag.listview.ActivateItem("FD3, Copies (>=0)");
ag.listview.ItemValue = "8";
agb.Regen();
Vallence is offline   Reply With Quote
Old   June 12, 2017, 19:07
Kapi is on a distinguished road
Hi Vallence,
//ag.bodyPick;
ag.gui.SelectAll();
You shud pick either the 3D edge at center or pick "ZX Plane" rather than picking all bodies. Try to do manually so you will understand
use "40" instead of evently spaced
try to put exactly what is in the pattern so "(FD3, Copies (>0))" will work
Kapi is offline   Reply With Quote
Old   June 12, 2017, 23:54
LC
Hi KAPI!
Thans for your reply. I have seen the advice you suggested, it is not the essence of the problem. What i want to do is to select XYPlane's YAxis.
Old   June 13, 2017, 00:07
why do you have to select Y axis specifically?
if you only give reference to XY plane, it should work!
Old   June 13, 2017, 00:14
Question
LC
Hi Kapi,Thank you for your prompt reply.
I tried the following code,but it deos not work.
var PatAxis=XYPlane.GetYAxis();
agb.AddSelect(agc.TypeEdge3d, PatAxis);
ag.listview.ItemValue ="Apply";
The key question is i do not know how to select YAxis and let it work .
Old   June 13, 2017, 18:52
i will give it a go and let you know
Vallence likes this.
Old   June 13, 2017, 21:51
Question
LC
I upload the actual result and the result I expect. You can find the difference between them.
File Type: pdf the actual results after running the JS Code.pdf (119.7 KB, 12 views)
Old   June 13, 2017, 23:31
Smile With the help of many friends, I solved this problem
LC
Thanks very much for Kapi and EFRIVIDA's selfless help,now I solved the problem that bothered me for several days. I will publish the code for my friends Who meet the same trouble with them.
//Plane
//Sketch1
//Edges
with (p.Sk1)
a=10
b=20
h=20
//Sketch2
//Edges
with (p.Sk2)
a=14;
b=24;
h=10;
h0=12;
with (p.Plane)
return p;
ps1.Sk1,
ps1.YAxis,
agc.DirNormal,
360.0,
0.0,
agc.No,
0.0,
0.0);
agb.Regen();
ps1.Sk2,
ps1.YAxis,
agc.DirNormal,
3.0,
0.0,
agc.No,
0.0,
0.0);
// Key Code
var PF1 = ag.gui.CreateSpot();
ag.listview.ActivateItem("Type");
ag.listview.ItemValue = "Construction Point";
ag.listview.ActivateItem("Definition");
ag.listview.ItemValue = "Manual Input";
ag.listview.ActivateItem("FD8, X Coordinate");
ag.listview.ItemValue = "0";
ag.listview.ActivateItem("FD9, Y Coordinate");
ag.listview.ActivateItem("FD10, Z Coordinate");
agb.Regen();
var PF2 = ag.gui.CreateSpot();
ag.listview.ItemValue = "100";
agb.Regen();
var LF1 = agb.LinePt();
LF1.AddSegment(PF1.GetPoint(1, 0),PF2.GetPoint(1, 0), 0);
agb.Regen();
ag.edgePick;
ag.gui.SelectAll();
//ag.listview.ItemValue = "Evently Spaced";
ag.listview.ItemValue = "40";
agb.Regen();
Old   June 14, 2017, 01:32
good work and thanks for posting final codes.
Old   June 14, 2017, 02:44
Hey vallence,
Did this work because you changed the geometry?
previously 1 of the edges was coming in center which is why you were trying for Y axis in XY plane.
New geometry shows the body is away from center, is that why
ag.edgePick;
worked?
Cheers
KAPI
Old   June 14, 2017, 02:57
Default Explain
  #11
LC
I tried different a'values while I was debugging the code.Different a shows different result. Under current code,the final result can not vary with
a.
with (p.Sk2)
a=15 //when a=0 the final result is the same
b=24
h=10
h0=12
axis, pattern
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 09:54
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
