[ANSYS Meshing] 2D equilaterals triangles in simple geometry
Old   June 16, 2017, 19:01
Default 2D equilaterals triangles in simple geometry
Ulixes is on a distinguished road
Hi everybody,
for a while I have been trying to mesh a geometry with triangles for a volume-of-fluid method use. Since you may know, the reconstruction of the interface between two fluids is heavily dependent on the mesh.
My idea was to use triangles as equilateral as possible. Hence I used the multizone meshing method imposing that the free surface have to be meshed with triangles. Basically the geometry is a rectangle that abruptly expand in a widther rectangle. In the larger zone the mesh is amazingly regular with equilaterals triangles. However in the narrower triangle, triangles are create by splitting a square in two by it diagonal. This shape is not suitable for VOF.
On the other hand if a use simple triangle method the mesh is not regular enough (maybe I missed to set some parameters) and the boundary layer has a lower quality.
Hence my request is: does someone know how to mesh a simple 2D rectangle with equilaterals triangles and boundary layer ?
Ulixes is offline   Reply With Quote
Simple Beginner User Question on 'geometry' scottimus FLUENT 5 March 27, 2012 13:17
[ICEM] Simple Geometry Poor Results tav98f ANSYS Meshing & Geometry 4 August 4, 2010 13:36
[ICEM] Creating Simple Geometry Mudblood ANSYS Meshing & Geometry 1 June 8, 2010 20:26
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
