June 17, 2017, 21:45 |
convert surface to solid
dilaw meda
Rep Power: 8 |
hello ; i creat a nozzle and i want to export it as a solid not Surface body; how to do that ?
June 18, 2017, 20:23 |
Rep Power: 14 |
give thickness to it?
June 19, 2017, 16:04 |
dilaw meda
Rep Power: 8 |
June 19, 2017, 23:00 |
Ghazlani M. Ali
Rep Power: 29 |
There is no point to converting it into solid. I think what he meant is fill the void with a solid part so he can compute the flow... In this case, this is a very basic step in CFD and you have to start by the tutorials...
June 19, 2017, 23:28 |
Ericho
Yeahh,if you want to compute the flow you must have solid part in your geometry.Usually I make my solid part with Solidwork and then export my geo. to IGS.
Sent from my Mi 4i using CFD Online Forum mobile app |
How to convert the surface force to volume force on the interface in VOF model? | aestas | Fluent UDF and Scheme Programming | 4 | March 23, 2021 21:13 |
solid to solid surface contact | honeybunch | FLOW-3D | 0 | May 31, 2016 03:32 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Blood drop impacting a solid horizontal surface (glass) | gahmed | FLUENT | 0 | November 14, 2010 17:52 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
