[DesignModeler] create concentric ring inlets |
June 26, 2017, 21:56 |
Omar jumaah
Rep Power: 10 |
Hello All,
How can I create concentric ring inlets on one surface body in design modelar, any suggestions please . (note : I used imprint faces and projection but they didnot work, my bad !! ). thanks |
June 27, 2017, 02:32 |
Gwenael H.
Rep Power: 20 |
Hello Omar,
You can use the projection tool for that. Have fun |
June 27, 2017, 03:38 |
Rep Power: 12 |
Just create a sketch with the desired circular regions and create surface bodies from them. Then you can simply imprint the faces on the larger surface (big circle as the traget body and the surface bodies as tool bodies). Now you can define the concentric regions as you wish.
June 28, 2017, 01:32 |
Omar jumaah
Rep Power: 10 |
Thank you Gweher and Divergence for replying. Actually, I created a sketch on the required surface then extruded the sketch as imprint face. It works
Two pressure inlets problem | Medison | CFX | 1 | August 22, 2012 06:50 |
Meshing Ring Element | Jalen | ANSYS Meshing & Geometry | 2 | October 20, 2009 09:21 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 02:29 |
