January 30, 2024, 14:20 |
Flow promoter meshing
Rep Power: 6 |
Hello everyone ,
I have been trying to learn meshing lately and while doing so , I came across a problem in my research. This is a microchannel with some flow promoters that I have been trying to mesh. So far I have tried to apply multizone meshing and edge sizing. I also tried to use inflation without multizone , however the quality of the mesh decreases badly . I was wondering if I am missing something here. I have been unable to mesh in either of the methods used. Note the top wall is a plane wall and no vortex generators have been used there |
mesh |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 07:00 |
[ANSYS Meshing] how to fix meshing fail due to sweep mode controls on simple multiphase flow sim | oberstar | ANSYS Meshing & Geometry | 1 | September 28, 2017 09:34 |
[ANSYS Meshing] Suggestions needed for meshing axial flow pump with thin tip gap | jason580315 | ANSYS Meshing & Geometry | 0 | October 23, 2016 22:35 |
[ICEM] ICEM Blocking and Meshing - Flow over Periodic Hill | Crank-Shaft | ANSYS Meshing & Geometry | 8 | April 29, 2014 04:11 |
[ICEM] Multizone meshing Problem for External Flow Meshing | Hybrid | ANSYS Meshing & Geometry | 9 | March 29, 2013 10:24 |
