[ANSYS Meshing] Fluent Meshing results in very high skewness |
August 30, 2017, 09:23 |
Rep Power: 10 |
My geometry is a kind of a helix. The flow flows through the helix. So I made a mesh in Ansys Meshing and I have very high skewness values. I have about 10.000.000 cells My min. Skewness is: 1,71641165032099E-05 My max. Skewness is: 0,999397641071006 No matter what I try. My skewness is always round about 0.999. I selected as preset: CFD, relevance is 100 and everything is set to pretty fine. Many said that the Inflation might cause problems. I tried it turned on program controlled and off. Both had similar results. So I looked up at cfd-online already and tried some of the tips. I provide some pictures with a very high skewness cells. To the names of the pictures: W_Prism is with turned on Inflation and WO_Prism is with turned off Inflation. Any suggestions on how to fix these cells? Thank you in advise. FFD Last edited by FFD; August 30, 2017 at 09:24. Reason: Adding the main question. |
cfd, fluent 14, mesh 3d |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
[ANSYS Meshing] Ansys meshing result very high skewness | m5edr | ANSYS Meshing & Geometry | 18 | February 3, 2020 11:35 |
High skewness on importing Pointwise mesh in Fluent | Shubham_SD | Pointwise & Gridgen | 0 | February 7, 2017 09:56 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
