January 22, 2017, 09:15 |
Error reading mesh in Fluent
Arun
Rep Power: 14 |
Hello Every one,
The problem is when i read mesh on fluent it shows that it have an error and i think that i was making some mistake in meshing. The error: eading "D:Mesh\fluent.msh"... 218811 nodes. 1173538 tetrahedral cells, zone 6. 2309061 triangular interior faces, zone 7. Warning: Invalid face type 17. Skipping. 558 triangular velocity-inlet faces, zone 9. 712 triangular outflow faces, zone 10. 3015 triangular wall faces, zone 11. 7438 triangular wall faces, zone 12. Building... mesh WARNING: Cell 55 of thread 6 is missing face 3. Cell Centroid is (219.461326, 84.190658, -1291.033701). Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error Object: #f Reading "D:Mesh\test cube.msh"... 16922 nodes. 87860 tetrahedral cells, zone 8. 171967 triangular interior faces, zone 9. Warning: Invalid face type 17. Skipping. 867 triangular wall faces, zone 11. 1720 triangular wall faces, zone 12. 86 triangular velocity-inlet faces, zone 13. 84 triangular outflow faces, zone 14. Building... mesh WARNING: Cell 102 of thread 8 is missing face 3. Cell Centroid is (0.979784, 1.005996, 0.116820). Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error Object: #f I tried again with different mesh file that i have done long back it was reading with out any error. I did two different model recently and also one easy model to test and all the model i did now show the same error. i feel that i'm the one who is making the error. I would appreciate help on this. Thank you! |
September 9, 2017, 03:23 |
Rep Power: 14 |
I have the same problem
did you solve this problem ? |
September 9, 2017, 10:14 |
Solved
Arun
Rep Power: 14 |
Yes, I should have posted it long back. It happens with you use wall and sold in boundary.
can you just upload your mesh (as a picture) with boundary. I changed to wall instead of solid because it was hallow in my case. |
error object: #f, icem 14.5 |
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) | Joachim | ANSYS | 3 | April 24, 2016 16:52 |
[ICEM] Fluent reading wrong mesh type | Tommorrice | ANSYS Meshing & Geometry | 1 | March 15, 2016 17:32 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 02:22 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
