[TurboGrid] 2 different blades
Old   December 20, 2017, 04:41
Default 2 different blades
Jiri
Jiricbeng is on a distinguished road
I want to use Turbogrid 18.1. My aim is to design radial diffuser with cascade vanes - two types of vanes (it is not actually splitter) with different shape. That is 9 vanes of design "A", 9 vanes of desing "B".
In previous versions of turbogrid, in Blade modeler, I created two export points - export point1 for "A" and export point2 for "B. The topology I selected was traditional with control points. In Turbogrid 18.1, the architecture, only ATM optimized is available. I read in Help there is not necessary to use "export points" feature. So I only created the two vanes and dragged the line in workbench from design modeler to turbogrid. I cannot se however the two vanes in "mesh" panel, only in "geometry" panel, and there is everything red.
Is there any tutorial how to do it in version 18.1 ?
Jiricbeng is offline   Reply With Quote
Model turbine blades as baffles kmallick OpenFOAM Pre-Processing 1 March 21, 2017 23:40
[ANSYS Meshing] is it possible to create virtual edges on the blades er_ijaz ANSYS Meshing & Geometry 0 November 3, 2013 05:15
helicopter blades cfd-star Main CFD Forum 1 May 23, 2004 14:24
helicopter blades cfd-star FLUENT 0 May 21, 2004 06:06
Why the streamline passes through blades Jeniffer CFX 2 November 18, 2003 01:25
