[ICEM] Problem with exporting mesh after smoothing
Old   December 28, 2017, 09:39
Default Problem with exporting mesh after smoothing
Wroobs is on a distinguished road
I'm trying to mesh an airfoli in ICEM (2D, quads) and faced a problem with converting smoothed mesh to output mesh.
The problem is that the output mesh is the same as the pre-mesh before smoothing (take a look at the pictures). When I convert pre-mesh to multiblock mesh everyhing is ok but then if I i want to write input files to fluent the problem appears. The same situation is when I'm trying to smooth multiblock mesh and then export it fluent.
Could you tell me what I'm doing wrong?
Output mesh -> https://ibb.co/jDpmHG
Smoothed mesh -> https://ibb.co/mWwoWb
Wroobs is offline   Reply With Quote
Old   December 29, 2017, 05:41
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Use Convert -> Unstructured Mesh
Not the multiblock mesh option
shereez234 is offline   Reply With Quote
Old   January 4, 2018, 16:12
Thanks for your replay, converting to unstructured mesh works but I still don't understand why it's necessary to use this option while the mesh is based on quads not triangles?
Additionally I'm wondering if there is any option that let me set mesh cells in boundary layer around the airfoil perpendicularly to its curvature through some distance? Is there any better option than o-grid mesh around the airfoils divided into many blocks with mesh shaped manually?
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 21:54
[ICEM] Mesh Smoothing problem star ANSYS Meshing & Geometry 2 December 21, 2013 03:15
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
