[Other] Airfoil Inserting Problem [SpaceClaim] |
February 24, 2018, 06:57 |
Rep Power: 8 |
Hello friends,
I have a problem while inserting airfoil coordinates to ANSYS SpaceClaim. 1- Even the airfoil that I do the same as the tutorial has even sharper lines 2- When I pull my airfoil, all points transforms to edges. I don't want them to seen like edges, I need smooth curves. Do you have any idea about this problem's solution? Last edited by planoturk; February 24, 2018 at 11:43. |
February 27, 2018, 12:51 |
Gert-Jan
Rep Power: 27 |
You should control the angle at the end of the edges. This can be done in Spaceclaim. I don't know the exact button but it is in the drawing menu. Just hoover over the icons to see which button you need.
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Problem Meshing Airfoil | erodv | OpenFOAM | 12 | January 11, 2012 17:46 |
Fluid Structure Interaction problem for airfoil | vinair39 | OpenFOAM | 0 | February 8, 2011 07:57 |
[FloWorks] Request advice for an airfoil calculation problem | Bogey Jammer | Main CFD Forum | 0 | September 29, 2009 17:06 |
solving airfoil like square cylinder problem? | zonexo | Main CFD Forum | 1 | May 27, 2006 15:16 |
