February 26, 2018, 11:20 |
Meshing error encountered
Anirudh
HI guys
I am working on a project in which I am simulating fluid flow in a 2D scramjet combustor. I used Ansys design modeler to create a rectangular combustion chamber with a triangular strut in the middle. I am trying meshing using the Ansys Meshing tool. I have given a face size of 0.25mm and inflation of 2.5e-03mm with a 20% growth rate and for 20 layers. The software does the meshing but says " Invalid geo element encountered meshing aborted" but it displays a mesh. When I simulate it in fluent after about 80 -100 iterations it is diverging. I am not able to make out if the problem is with the mesh or with the geometry. Please help. |
February 27, 2018, 12:54 |
Gert-Jan
Rep Power: 27 |
Did you try to improve the mesh in Fluent? Mostly that helps.
February 28, 2018, 10:12 |
Anirudh
Thankyou that helped!!
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 | Touré | ANSYS Meshing & Geometry | 2 | September 26, 2017 05:41 |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
