February 27, 2018, 11:41 |
Split blade surface
AHMAD
Rep Power: 12 |
Hi all
I am just wondering if it possible to split the rotor blade that I have meshed in Turbogrid. I would like to separate the blade surface into the 4 surfaces; Leading edge, Suction side,Pressure side and Trailing Edge. Currently, the blade surface is generated as a whole not divided into the above-mentioned sections. Really appreciate any help. Best Ahmad |
February 28, 2018, 09:54 |
AHMAD
Rep Power: 12 |
March 1, 2018, 06:43 |
AHMAD
Rep Power: 12 |
Yes, ICEM gives me better control of the density of the grid points.
My initial domain is meshed using ICEM but I need a fast way to generate the mesh since I am working on optimization of the geometry. Anyways, I just found out how to import the mesh to ICEM. |
Problem to get force value on blade surface | Rockytime | CFX | 6 | February 2, 2017 22:20 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
How to Capture the Nodes on the Blade Surface | Araz | CFX | 13 | April 28, 2011 05:47 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull | eee | CFX | 2 | August 28, 2009 08:36 |
