February 27, 2018, 23:41 |
Grid independence test
Binama Maxime
Rep Power: 11 |
Hello there !
I wanted to get some info about a quick way by which i can generate different grid numbers for the same geometric model. Any quick hint ?! I am trying to simulate the transient flow through a pump turbine, and i wanted to first do the grid independence test where i need to be testing different grid numbers ! the mesh that i have now has been generated through ICEM (it's a structured mesh). Any intervention is highly appreciated ! Thank you |
February 28, 2018, 03:28 |
M
Rep Power: 12 |
I can't really speak for ICEM since I don't use it. But I think it is a lot of effort there from what I have seen.
ANSYS Turbogrid allows quickly changing the overall mesh resolution by a single parameter. For example you can specify some regional values and also a target overall mesh size, say 500.000 cells, 1.000.000 cells, and so on. |
February 28, 2018, 04:21 |
#3 | |
February 28, 2018, 04:23 |
yanki cob
Rep Power: 8 |
March 2, 2018, 07:22 |
March 2, 2018, 07:33 |
yanki cob
Rep Power: 8 |
March 2, 2018, 08:34 |
yanki cob
Rep Power: 8 |
So let's say I have a mesh size of 1000000, and I want to double it without changing the geometry. I can do this with changing just one parameter in ANSYS Meshing?
Ansys fluent grid independence test | Jesh | FLUENT | 11 | February 4, 2020 09:54 |
Grid independence check in transient simulation | abhi084 | Main CFD Forum | 1 | December 4, 2014 15:55 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
