March 1, 2018, 04:14 |
Hex cells in mesh density
Ben
Rep Power: 9 |
Hi everyone, I'm attempting to mesh an external flow case (aircraft) where a density refinement is made to capture/model a wing wake (please see picture).
However, ICEM fills this density region with tet cells whereas I would like to have hex cells instead. The spatial resolution of the density region is 0.07m in cell edge length. For tets, I created the density for size of 0.07m and ratio of 1.2. However like I mentioned, this gives me tet cells. Could someone please enlighten me on how to accomplish this but with hex cells of the same edge length (0.07m) instead? I should add that I followed the steps from the wingbody and helicopter tutorials to create this mesh. Your help means a lot to me. Thank you in advance! |
March 2, 2018, 06:37 |
Ben
Rep Power: 9 |
Thanks for replying Sijal,
Under tetra to hexa, it gives me the option via a drop down menu to select which elements I would like to convert. However, I would like to only convert the cells in the density region but the available options are only parts where none of which is the density. Could you clarify this please? Thanks again. |
March 2, 2018, 08:58 |
Ben
Rep Power: 9 |
Yes, I'm aware of the option but what I am referring to is that I can't seem to select only the tets in the density region (orange in my pic). As you can see there is no option for me to select my density, neither can I select it from the screen. The entire volume mesh is made out of tets, by the way.
In your case you're converting the entire sphere, which I believe you selected it from the 'Select Parts' window? Thank you for your patience. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
