March 5, 2018, 17:18 |
How to combine two cells?
Rep Power: 9 |
Hello all,
I have encountered a strange problem. mesh.jpg I used CutCell to generate this mesh. ANSYS split the boundary cell into 1 and 2, which should be a prism like 3. I need the boundary face to be periodic, so this strange split is not acceptable. I searched online. It says that only non-cutcell mesh can apply match control. Seems like the only way is to manipulate the mesh manually? Is their any tool to fix the mesh? Thanks. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[snappyHexMesh] snappyHexMesh does not remove internal cells | Binglian Hu | OpenFOAM Meshing & Mesh Conversion | 16 | June 3, 2021 09:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
