March 6, 2018, 06:14 |
Gert-Jan
Rep Power: 27 |
1) Create a small round surface (end face or start face) of your helical.
2) Create 4 points that describe your larger helical diameter. Say 0°, 90° 180° and 270°. Make sure you shift the points a bit in vertical distance to follow the helical shape. Let point 0° be the center of your small round surface from step 1. 3) connect the four points by a line. 4) extrude the face a long the line 5) repeat 2, 3 and 4 to extend the helical shape You might need extra points at the end or start of your line to control the starting angle. |
March 7, 2018, 10:59 |
Vish
Rep Power: 13 |
Is your question about creating the geometry or meshing it in ICEM?
If you want to create the geometry, then I recommend using SpaceClaim. If your question is about meshing it, then perhaps I can help. Thanks |
[Other] How to make ribs in helical tube in Spaceclaim? | teguhtf | ANSYS Meshing & Geometry | 8 | April 24, 2018 21:11 |
[ANSYS Meshing] Problem in Meshing a tube in tube Helical HX | Maradona | ANSYS Meshing & Geometry | 0 | August 4, 2014 07:50 |
[ICEM] Can I create hanging nodes in ICEM? | leekj92 | ANSYS Meshing & Geometry | 7 | April 9, 2013 01:02 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
[ICEM] Trying to create a similar prostar tet mesh using ICEM | cfdengineer | ANSYS Meshing & Geometry | 2 | March 13, 2010 18:02 |
