[ANSYS Meshing] Control number of element in thickness with ANSYS MESHING |
March 8, 2018, 16:27 |
Emanuele Spinosa
Rep Power: 11 |
Dear all,
if I have a plate, which is 1 mm thick, and I want to mesh it in ANSYS Meshing, how can I make sure that there are 4 elements in thickness throughout the plate? Please let me know. Cheers, Emanuele |
March 8, 2018, 21:16 |
Rep Power: 11 |
Swept mesh with 4 divisions.
March 9, 2018, 02:02 |
Emanuele Spinosa
Rep Power: 11 |
March 9, 2018, 03:33 |
Emanuele Spinosa
Rep Power: 11 |
Why is this body now sweepable? Logically it should be ...
March 9, 2018, 06:53 |
Stuart
Rep Power: 25 |
There may be an extra geometry point or such that is very small. Show the points to see this. There has to be a mismatch (even very hard to see) between the face faces if it is saying it's not sweepable.
March 9, 2018, 07:43 |
Emanuele Spinosa
Rep Power: 11 |
The circular part in the middle is a split face. I did this to have a conformal meshing with a cylinder which is above it ... Is this the problem? I tried to merge the faces using Virtual Topology but I could not do it either
March 9, 2018, 14:52 |
Emanuele Spinosa
Rep Power: 11 |
Hi guys, I'm still stuck, do you know how to solve this question? Thanks a lot for your help.
E. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
