[ICEM] 3D Inflation blocking in ICEM CFD
Like Tree1Likes
  • 1 Post By Far
Old   March 10, 2018, 03:28
Default 3D Inflation blocking in ICEM CFD
M. Bahaa
mbahaa is on a distinguished road
I was trying to block 3D corner inflation in ICEM using the same 2D approach discussed before in this thread, and now I believe that ICEM manual blocking approach is actually the best method for meshing this geometry, I have created this sample geometry for demonstration of the technique, however, I am unable to slice/merge the blocks on ICEM consistently to represent this geometry, I always end up with connectivity inconsistent with the geometry and/or degenerated blocks.
I went through the following:
1. slice the initial block into 9 blocks
2. delete block #7
3. merge block #5 and #8
4. merge blocks #6 and #9
5. associated edges and vertices accordingly
Thanks in advance
mbahaa is offline   Reply With Quote
Old   March 10, 2018, 13:29
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Like this?
https://www.youtube.com/watch?v=GX1Wd04NoHA
mbahaa likes this.
Far is offline   Reply With Quote
Old   March 11, 2018, 05:39
Default Sincere Thanks
M. Bahaa
I can see you have made this video specifically as an answer for my question, thanks a lot for your efforts, and the video is very helpful indeed, I will try it on my full version geometry and let you know how it went with me.
Thanks again, best wishes
[ICEM] ICEM CFD inflation (prim mesh) problem erzdemir ANSYS Meshing & Geometry 2 April 17, 2014 03:05
How to create boundary layer using ICEM cfd and using blocking meshing strategy costy Main CFD Forum 0 April 12, 2014 04:14
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
which of them is better? saha2122 ANSYS Meshing & Geometry 5 June 18, 2010 06:35
