[ICEM] Aspect Ratio Problem
Old   March 11, 2018, 18:26
Default Aspect Ratio Problem
Ebubekir
thebuaa is on a distinguished road
I try to generate a mesh in ICEM CFD for naca0012. However, Aspect Ratio be a huge problem for the following data.
Dynamic Viscosity: 1.13E-03 (for sea water)
Velocity: 6.625 m/s
Density: 1025 kg/m3
Chord Length: 1 m
Y+ desired: 1
Since the k-omega SST turbulence model is selected, y+ desired should be smaller than 5.
Finally, pointwise y+ calculator give me that value for the wall spacing: 8.9E-06
This value, which is so small be a problem for the aspect ratio.
As I know, Aspect ratio should be smaller than 100. But in this condition aspect ratio is defined as bigger than 10000.
How can I overcome this problem?
thebuaa is offline   Reply With Quote
Old   March 12, 2018, 09:11
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Velocity: 6.625 m/s
Density: 1025 kg/m3
Chord Length: 1 m
Y+ desired: 1
Increase the number of cells streamwise on airfoil. By the way modern CFD solvers can solve really high aspect ratios (in thousands) unless it is ridiculously high this is not a problem in my opinion.
shereez234 is offline   Reply With Quote
Old   March 14, 2018, 10:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Velocity: 6.625 m/s
Density: 1025 kg/m3
Chord Length: 1 m
Y+ desired: 1
1. Increase no of nodes on airfoil surface.
2. Moreover try Y+ ~ 10 would you same results as Y+~-
Watch this video for same : https://www.youtube.com/watch?v=3VuZiDIl704
Far is offline   Reply With Quote
Old   March 14, 2018, 15:07
Ebubekir
Thank you so much.
Old   March 14, 2018, 15:10
Ebubekir
Dear Sir
I have watched your video before. But you don't check the aspect ratio in your video. And in my opinion, aspect ratio shoud not lower than 1000 for your mesh.
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
Grid Aspect Ratio harishameed33 Main CFD Forum 1 August 11, 2012 22:35
[ANSYS Meshing] How to Control Aspect Ratio in Ansys meshing mecbe2002 ANSYS Meshing & Geometry 0 May 28, 2012 07:56
[ICEM] check aspect ratio camoesas ANSYS Meshing & Geometry 2 November 14, 2011 09:38
Maximum Aspect Ratio pz1337 FLUENT 0 April 6, 2011 04:45
