[ICEM] MultiZone could not generate a valid mesh issue with ICEM |
June 4, 2018, 22:24 |
Davide Concu
Rep Power: 8 |
Hello everyone,
I am trying to generate a structured mesh of different parts of a valve using Multizone option and ICEM. After creating the mesh of this part and checking the mesh quality I converted it to unstructured mesh, saved and closed ICEM, but when back in WB it displays the error "Multizone could not generate a valid mesh". I don't really understand if the mesh I created has a poor quality or there is some other issues with Ansys Meshing. Can also attach the .prj files in case Thank you! |
June 5, 2018, 03:41 |
Gert-Jan
Rep Power: 27 |
Not sure if MultiZone requires a conformal mesh, but at least your mesh is not conformal. So,maybe that is the problem.
June 14, 2018, 00:41 |
Davide Concu
Rep Power: 8 |
For other visitors that had the same issue:
The body is divided into discontinuous body (block) virtually in ICEM. Although this condition is not a problem within ICEM, when returning to ANSYS Meshing, it is impossible to represent a form in which one solid body is divided into multiple parts. By splitting the body from the beginning in spaceclaim or design modeler there is no problem. |
June 14, 2018, 00:45 |
Davide Concu
Rep Power: 8 |
Apparently with the multiZone option is possible to generate a non conformal mesh, but, when using ICEM, all the single part have to be meshed separately
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | ANSYS | 1 | March 9, 2015 22:17 |
[ICEM] The decent procedure to generate tet mesh by ICEM | sharonyue | ANSYS Meshing & Geometry | 0 | December 22, 2014 09:39 |
[ICEM] Mesh issue in ICEM | itsme_kit | ANSYS Meshing & Geometry | 2 | October 15, 2014 04:32 |
How to export multizone uns mesh from icem to cgns | july | CFX | 1 | May 1, 2013 09:59 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
