[ANSYS Meshing] About messing
Like Tree2Likes
  • 1 Post By bpulat
  • 1 Post By bpulat
Old   December 16, 2018, 23:30
Default About messing
munu
munu is on a distinguished road
How to do node to node connectivity in Ansys 18 between solid and fluid domain. Does anyone know?
munu is offline   Reply With Quote
Old   December 17, 2018, 03:08
Baris PULAT
bpulat is on a distinguished road
You can do that in geometry editing by SpaceClaim/DesignModeler or you can also do that in the ANSYS mesher.
- For SpaceClaim http://help.spaceclaim.com/2015.0.0/...edTopology.htm
- For DesignModeler https://www.sharcnet.ca/Software/Ans...dTopology.html
- For ANSYS Meshing https://www.sharcnet.ca/Software/Ans...ode_merge.html
bpulat is offline   Reply With Quote
Old   December 19, 2018, 05:33
Default Queries regarding ANSYS
munu
How to give flux in the interface, can you tell?
Old   December 19, 2018, 06:09
Baris PULAT
Well since you can't do that in ANSYS Meshing & Geometry part, you need to assign it as a boundary condition in your solver software (FLUENT, CFX, AIM, etc...).
munu likes this.
Old   December 20, 2018, 00:10
munu
After messing when I go to set up in boundary conditions that part should be a wall so that I can give flux but it creates an interface where I unable to give boundary condition.
Old   December 20, 2018, 05:41
Baris PULAT
Since there is no schematic of your problem, I am just going to assume things.
I think you are trying to simulate not the interface but different zones between solid and fluid, not fluid/fluid.
So if this is your case, you have to change your zones to fluid and solid according to your problem then you can assign an interface as a wall in your solver.
Another possibility is that you have a fluid and solid zone separately but the solver automatically created the connection between them as an interface where you should then change it to the wall manually.
munu likes this.
Old   December 21, 2018, 04:21
munu
Plz see the attachment, and green colour part is my part where I suppose to give flux, but it creates an interface. Outside the tube, it is the air domain.
Old   December 22, 2018, 05:46
munu
still, I am unable to change the interface to the wall.
Old   January 8, 2019, 03:46
Baris PULAT
Sorry for the late reply,
But as I said above you can change your boundary conditions in your solver settings.
Even if the solver creates automatically the interface in the beginning, by simply naming the surface in ANSYS Meshing with Named Selection you can assign another boundary condition to that spot in your solver.
Some misleading about the treatment of coupled boundary liuhuafei OpenFOAM Bugs 6 February 20, 2018 10:11
Plot xy messing variable .help soufiane002 FLUENT 0 September 27, 2017 15:04
[mesh manipulation] CreatePatch chris1980 OpenFOAM Meshing & Mesh Conversion 8 November 16, 2016 15:44
Messing alphaEqn solver with meshPrimitivePtr->movePoints(newPointsRef, oldPointsRef) jmf OpenFOAM Programming & Development 0 August 21, 2016 15:36
InterDyMFoam dynamic messing in parallel fails under nonquiescent conditions adona058 OpenFOAM Running, Solving & CFD 5 August 19, 2010 11:47
