[Other] Need Advice! Simulation of flow at the aft of a ship
Old   November 22, 2018, 06:56
Default Need Advice! Simulation of flow at the aft of a ship
Nikhil
nikhil07071990 is on a distinguished road
Hi!
I am doing a study on Energy Saving Devices (ESDs) which are fitted either before/at/after the propeller and help in reduction of rotational/axial/pressure losses. Some examples are pre/post - swirl stator, Wake equalising duct, Nozzle, Propeller boss cap with fins etc.
I was thinking of performing CFD calculations(aft-section) on a hull- form(TBD) with the ESD attached (TBD). I am fairly new to CFD and have used ANSYS CFX for studying the simulation of flow around an airfoil.
I was wondering which software could I use to perform the above simulation of a flow around aft of a hull-form with propeller and ESD attached. Is it possible in ANSYS CFX? If not, then which software would be easy to learn and perform these simulations. Thanks!
nikhil07071990 is offline   Reply With Quote
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow Aliiiii OpenFOAM Running, Solving & CFD 1 February 27, 2019 12:26
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Multiphase flow for flow around ship gundul CFX 5 September 2, 2008 16:06
Flow around ship Gundul CFX 1 August 14, 2008 00:45
