Rep Power: 0 ![]() |
Hello everyone! I've been trying to mesh this geometry and I'm having a few problems. It seems pretty straight forward but I'm having trouble at the S-duct.
The thickness (green part) doesn't continue all the way around and I get bad elements at the point where it gets cut off. What I've tried to do is use 2 o-grids. One run down the bell mouth pipe and defined the thickness of the S-duct (as a solid) and the other was used to define the larger bell mouth pipe. However, since the bottom blocks of the o-grid are deleted at the S-duct, it produces bad elements at the interface of the S-duct and pipe. I can delete the bottom block on the ramp too but it messes up at the point where the ramp starts. I've attached the geometry and the blocking. I can provide more information too. Any help/ideas will be appreciated. Thank you!! |
[ICEM] Correct blocking and Ogrid in ICEM | salumi | ANSYS Meshing & Geometry | 3 | November 8, 2016 10:10 |
[ICEM] Blocking | wali | ANSYS Meshing & Geometry | 2 | September 8, 2014 14:19 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
