February 17, 2019, 15:52 |
Create body from faces
Rep Power: 15 |
Hi all,
I'm having some difficulties trying to create a body made of 4 faces. The boy represents an open channel so the material will be "fluid". The four faces (see attached Figure) are:
How can I merge all 4 surfaces to create a body? Thank you. Kind regards, Edu |
body building, geometry fluent |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
