May 20, 2019, 05:04 |
Thin Regions Meshing Problem
CT
Rep Power: 10 |
Hi all!
I'm trying to generate mesh between thin sections (apprx. 2 mm). But It is very hard even though it seems easy. Because I have to generate prism layers at most 4 cm near rest of surfaces. Also I have thin cut regions. I tried ICEM-CFD and Workbench Meshing, also tried to use both of them at the same mesh but I couldn't handle it. Can anyone give me helpful advice? Btw, you can imagine my problem like you have an aircraft and trying to generate mesh both all aircraft surfaces and control surfaces which has tiny space. Thank you |
May 21, 2019, 09:49 |
CT
Rep Power: 10 |
Any help??
May 22, 2019, 02:04 |
M
Rep Power: 12 |
Provide some imagery of the locations causing trouble otherwise it is almost impossible to help you with this.
May 22, 2019, 02:21 |
Gert-Jan
Rep Power: 27 |
I know how to do it in ICEM. But it is difficult to explain.
Your question is like: "How do I build a car?" I don't know where to start. Meaning, your question should be more specific with pictures, etc. Show us what you did, what the result was and where you got stuck. |
icem, icem-cfd, mesh, workbench meshing |
[Commercial meshers] Separating regions Problem after importing from Fluent Mesher | peterhess | OpenFOAM Meshing & Mesh Conversion | 1 | March 1, 2016 08:45 |
[ICEM] Meshing Problem ? | Leifheit | ANSYS Meshing & Geometry | 3 | December 4, 2014 18:09 |
[Gmsh] Meshing thin, curved solids in Gmsh | tibich72 | OpenFOAM Meshing & Mesh Conversion | 0 | January 5, 2012 11:05 |
Meshing Regions Problem | m.nichols19 | OpenFOAM | 2 | January 12, 2011 02:09 |
Difficulty meshing a two region problem | james15 | STAR-CCM+ | 5 | August 19, 2010 01:10 |
