July 20, 2019, 20:41 |
Uncovered edges problem
Davide
Rep Power: 6 |
Hi. I'm new to ICEM, and I'm trying to create a 2D mesh.
I am getting this error: "WARNING: Mesh has uncovered edges. ANSYS Fluent needs a complete boundary (lines in 2D) are not associated with perimeter curves ". I tried everything that I found in this forum, and I associated the edges with the curves. As you can see, in the picture, the mesh lines are (I think) well done. How can I solve? Thanks! |
July 22, 2019, 05:21 |
Sebastian Engel
Rep Power: 20 |
Hi Davide,
after you have converted the premesh into unstructured, you can use the Check mesh feature, to look for uncovered faces (and many other problems). You'll find it in the Edit mesh tab. There you can uncheck all but the uncovered faces checkbox. Check mesh might ask you to create a subset of mesh elements with found uncovered elements. Accept. Then you can go into the Object tree and hide the mesh and only show the new subset containing the uncovered elements. Best, Sebastian |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[surface handling] surfaceFeatureExtract fails to generate .eMesh file from .stl file | buckleup | OpenFOAM Meshing & Mesh Conversion | 1 | August 24, 2018 09:44 |
[ICEM] Problem with parallel edges in ICEM | Twix | ANSYS Meshing & Geometry | 3 | November 21, 2015 08:30 |
icem 2 fluent mesh export edges association problem | zdunol | ANSYS | 0 | October 4, 2014 16:04 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
