October 13, 2019, 03:05 |
o-grid in ICEM CFD
RAJDEEP JAGDALE
Rep Power: 7 |
i am newbie to ICEM CFD. while blocking, when i try to create o grid on one of the block, it is creating extra edge on the face of another block.
Please find the attached screenshot. My objective to create o grid on one of the block. Please help me with it. Thanks in advance. |
October 14, 2019, 06:27 |
Sebastian Engel
Rep Power: 20 |
Hi Rajdeep,
it seems, you have not deleted the block in the gap permanently. If you delete a block without activating the option for permanetly deletion, then this block will be moved to VORFN instead. This way, the interconnection is maintained (in axial direction in your case). If you want to break the link, you need to delete the block which was in that gap permanetly. To do that, activate the VORFN part and try to locate that "deleted" block in the gap. If the link still there the ogrid you created downstream will be created through the whole blocking in that direction. You might see this phenomena when you draw your premesh and observe the mesh at the face of the wedge. Best regards, Sebastian |
October 16, 2019, 04:21 |
RAJDEEP JAGDALE
Rep Power: 7 |
Thanks a lot. It worked correctly as you said.
Using Single Grid with ICEM CFD | hariyo | ANSYS | 0 | June 24, 2014 10:03 |
[TurboGrid] turbogrid to icem cfd then icem cfd to fluent | tmeysam92 | ANSYS Meshing & Geometry | 0 | May 7, 2014 06:25 |
Learn ANSYS ICEM CFD | easy_astronaut | ANSYS | 2 | December 15, 2013 15:34 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 06:46 |
