[DesignModeler] SpaceClaim Scripting/Track Feature |
November 20, 2019, 16:20 |
Karol
Hello there,
I need to parameterize the exchanger tube model created by gradually turning/burnishing the round tube (in CAD it is realised with pulling through the next sections rotated about some angle). I care about the length of the perimeter of the subsequent external sections of the extruded tube to be equal to the outer circumference of the round tube, and further so that the outer surface area of the extruded tube is consistent with the surface area of the round tube from which the target tube was formed. Is there a way to parameterize the length of a given curve in SCDM or to keep the outer surface of the pipe constant with the possibility of changing its geometry? If so, please give me some tips. Thank you in advance for your help, DKarpio . |
parameterization, space claim |
[snappyHexMesh] Error: Feature line extraction is only valid on closed manifold surfaces? | anu.raghun | OpenFOAM Meshing & Mesh Conversion | 6 | December 20, 2023 01:14 |
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture | thiagomarinho | OpenFOAM Meshing & Mesh Conversion | 7 | May 7, 2022 09:19 |
[snappyHexMesh] surfaceFeatureExtract error- Feature line extraction? | anu.raghun | OpenFOAM Meshing & Mesh Conversion | 2 | July 2, 2019 10:43 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Explicit feature edge ref&snap in OF2.2 | Eloise | OpenFOAM Meshing & Mesh Conversion | 0 | May 9, 2014 11:39 |
