January 26, 2020, 11:28 |
Joining/merging lines
Rep Power: 6 |
Hello everyone,
I am simulating a quarter of a cylinder and I have problems with the circumference because ansys meshing splits the circumference in different arcs, which I do not want. I design the 3D with CATIA and import it by means of Design Modeler in .igs. Everything looks fine in Design Modeler (the line is continuous) but when I transfer the geometry to meshing (I am using workbench) the same line is shown split (I am attaching two screenshots: the design modeler with the line highlighted and the ansys meshing where the points are shown and it can be seen how the same line is split in four segments). How can I avoid this? Or how can I merge these lines in ansys meshing so there are the same line? I want to use edge sizing and these splits make it very difficult. Thank you and best regards! Cheers |
January 27, 2020, 14:23 |
Erik
Rep Power: 23 |
That is very annoying, and I have run into it several times.
I don't have an easy fix. Perhaps modeling this directly in design modeler would help, though I've seen issues there too sometimes. On something this simple, you shouldn't have an issue if modeled in design modeler instead of importing though. If anybody else has an easy fix, that would be appreciated. |
January 28, 2020, 14:49 |
Rep Power: 6 |
Thank you for your reply. At least I know I am not the only one
The thing is I would not know how to do all those geometries in Design Modeler, specially the curved and the diagonal lines, have you done it before? Furthermore, this is a quick geometry to show my issue the final geometry will be more complex than this. Cheers! |
January 28, 2020, 16:45 |
Erik
Rep Power: 23 |
Found a couple threads with ideas, but no perfect solution:
Ansys meshing - unwanted edge splits Also found this, which is not entirely applicable, but may be of some help: "Use the Repair>>Fix group>Extra edges, or to simply select the cylindrical edges that you see, and delete them. These two methods do not recreate the faces, but rather, remove the boundary (provided the face definitions are close enough to allow that) Since we are on that, if the faces are not close-enough, that is sometimes what the Simplify tool can do for you, take some currently-spline-but-close-to-simple faces, and replace them with simple faces." Let us know if you figure anything out. |
March 17, 2020, 14:10 |
#5 | |
Rep Power: 6 |
Anyway, I followed this tutorial for the Share Topology option, in case someone finds it useful: https://www.youtube.com/watch?v=4JhDn0V26l0 |
ansys meshing, join, lines, merge, split |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[DesignModeler] Need to create construction lines to plot data along them in cfd-post | Soheyl.ysf | ANSYS Meshing & Geometry | 0 | April 29, 2014 02:42 |
path lines | seeta | FLUENT | 1 | September 4, 2011 01:07 |
Plotting Residuals | ata | OpenFOAM | 12 | July 8, 2011 02:50 |
