[DesignModeler] Surface bodies to solid body.
Like Tree3Likes
  • 1 Post By Светлана
  • 1 Post By KLA
Old   February 18, 2020, 07:50
Default Surface bodies to solid body.
KLA
KLA is on a distinguished road
Hi all,
I have a geometry of a wing made of surfaces in catia using multi-section surfaces and fill. I don't seem to be able to transform it to a solid body on ansys fluent.
I tried to sew them using body operation but it always results in a surface and shows a warning: not all bodies could be sewn into a solid body.
Is there any way to transform my surfaces into a solid body?
Thank you all
KLA is offline   Reply With Quote
Old   February 18, 2020, 18:00
Svetlana Tkachenko
Светлана is on a distinguished road
Do you have Ansys SpaceClaim installed? It may be able to repair the imported geometry.
Can you fill these surfaces in DesignModeller instead of catia? You can create a surface from an edge loop. If this works, then you don't need the surfaces which were created in Catia.
If all of this does not work, can you make a small example? Create a simpler wing in catia and if it still has the same problem then attach it to your next post.
KLA likes this.
Светлана is offline   Reply With Quote
Old   February 19, 2020, 11:30
Post
KLA
Hi Светлана,
Thank you for your reply.
I have spaceclaim installed but I've never used it before. How can I correct the geometry on spaceclaim ?
I can't fill the geometry in design modeler. I have a clean version of the wing that I've created similar to this one on catia. The clean version works totally fine in ansys and I can make it a solid body without difficulties.
Old   February 20, 2020, 19:10
Svetlana Tkachenko
Hi KLA
There is a short intro here
https://www.ansystips.com/2018/05/cl...paceclaim.html
Could just go to the repair tab in spaceclaim and check everything (e.g. click each button), for a half of these buttons it says no problem found, for the other half it fixes something.
If the geometry is not confidential, attaching it here may be fruitful in case someone would like to give it a go.
Regards,
Svetlana
KLA likes this.
Old   March 10, 2020, 04:59
Smile
KLA
Thank you very much Светлана.
Spaceclaim repair function worked fine for my geometry. I was able to create a solid automaticaly by repairing the geometry.
Thank you again.
Светлана likes this.
ansys 16, design modeler, solid body
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 14:31
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 06:14
