April 7, 2020, 02:40 |
Merging of two different meshes
naveen k s
Rep Power: 11 |
Dear Foamers,
I'm trying to simulate flow over the bluff body case. For this purpose, I've created a mesh using ICEM CFD software. I have split up the mesh into two blocks and saved it as two different projects. 1. Block 1 (projects): It has finer mesh generated around the geometry and in the wake region. 2. Block 2 (project 2): It has a coarser mesh, and it resides around the Block 1 mesh. The pictures of these two projects are attached. Then in a separate new project, I performed these steps to merge them: 1. Imported the geometry of project 2 and project 1, and then chose the merge option to combine them. 2. Imported the mesh of project 2 and project 1, and then chose the merge option to combine the two meshes, so as to obtain a complete mesh (picture is attached). Now, my question is what should we do with the INTERFACE that is created between the two blocks. Please note that I will be importing this mesh to OpenFOAM. a. Is there any way I can remove this INTERFACE and get an errorless mesh. OR b. Whether there exists any B.C. that can be used at the INTERFACE. |
[Commercial meshers] ICEM - Internal patch appears despite merging meshes | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 1 | December 30, 2018 13:08 |
[ICEM] Merging of 3d meshes | Ali3031 | ANSYS Meshing & Geometry | 1 | November 4, 2014 10:54 |
[ICEM] Merging Hexa Meshes in ICEM | screech1987 | ANSYS Meshing & Geometry | 11 | March 13, 2014 11:45 |
merging meshes | amirr | OpenFOAM Running, Solving & CFD | 2 | July 23, 2012 09:30 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 09:22 |
