May 1, 2020, 11:28 |
How to "crop" a structured mesh
Rep Power: 6 |
Problem: I have meshed with ICEM a long duct with some features inside (structured mesh). Now I need to run a simulation of just a portion of it. The duct has got a squared section and the new domain can be simply obtained but slicing it up perpendicularly to the streamwise direction.
Question: Is there a way to "crop" my mesh so that I don't have to rebuild the structured mesh from scratch? |
May 1, 2020, 11:35 |
Gert-Jan
Rep Power: 27 |
If you have your mesh on your screen, you can manually delete obsolete elements in the Edit-mesh menu. Isn't that a viable way?
May 2, 2020, 05:45 |
Sebastian Engel
Rep Power: 20 |
Hi cfdEng_,
is there a reason you that you cannot simply split the blocking at the duct's new end? This approach would spell: Create a new outlet/inlet surface (geometry entity). Then split your blocking at that region. Delete (permanently) the now obsolete blocks, and re-associate the new boundary entities. Best, Sebastian |
structured mesh |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
