[ANSYS Meshing] Cyclone separator meshing
Old   August 31, 2020, 13:56
Default Cyclone separator meshing
CFDSim72
sirsammie72 is on a distinguished road
Hello, any tips on creating a hex mesh for a cyclone separator?
I have tried via youtube tutorials and gotten close, but I have a few questions/concerns.
I have split the geometry into several, sweepable bodies and then attempted to use edge-sizing to create the mesh (other than inlet which is multizone). sometimes the meshing works and sometimes it says the mesh failed to initialize. any ideas on why this is? I have not yet gotten all of the bodies to successfully generate mesh.
secondly, this method does not seem ideal for conducting grid independence studies? as the grid is not the same size depending on the length of the edge and the number of divisions. would a better method be to control element size, keeping in uniform across all edges, and then change that parameter for each edge every time a new grid independence test is conducted?
thank you
sirsammie72 is offline   Reply With Quote
ansys, cyclone, cyclone separator, fluent, grid independence
Particle separation in an axial cyclone Cloudseeker CFX 3 August 19, 2014 20:13
Steam-Water Vertical Cyclone Separator Munggang FLUENT 3 April 29, 2014 13:38
requiring solution for heat transfer from gas to solid particle in cyclone suvai79 FLUENT 0 September 1, 2012 05:48
pulverized coal cyclone burner Manuel Acosta FLUENT 9 May 24, 2007 05:04
Modelling Industrial cyclone behaviour Günther Hasse Main CFD Forum 3 October 12, 1999 19:34
