September 28, 2020, 20:29 |
Airfoil meshing
EGYPT,Mansoura
Rep Power: 5 |
Dear friends,
How can i solve this curvature in meshing of NACA 0012 closed TE and disappearance of vertical lines of the cells in the triangular blocks in the images airfoil1.JPG airfoil2.JPG |
September 30, 2020, 04:18 |
Stuart
Rep Power: 25 |
Did you follow the guide in these 3 part series on YouTube: https://www.youtube.com/watch?v=tYrbScUH9RE. Highly recommend ICEM User's watch these because there are so many questions posted here about meshing for aerofoil simulations.
September 30, 2020, 15:21 |
EGYPT,Mansoura
Rep Power: 5 |
I have applied the steps on my case and the mesh looks well.
but, i found some errors while checking quality of the mesh and i did smoothing three times. These are all what i face now, and the mesh can't be transported to FLUENT airfoil2.jpg airfoil3.JPG airfoil4.jpg airfoil5.jpg |
October 1, 2020, 07:54 |
Stuart
Rep Power: 25 |
The element size transition in the streamwise direction at the trailing edge is far too high. Aim for less than 20%. Likewise for the elements in the hexa block at the leading edge.
October 2, 2020, 07:12 |
EGYPT,Mansoura
Rep Power: 5 |
Ireduced the cells' size to improve aspect ratio and the quality, but i still facing the problem of uncovered faces and single edges around the airfoil.
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Meshing 3 Element Airfoil | mr.rushikumar | ANSYS Meshing & Geometry | 0 | March 1, 2014 22:57 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[GAMBIT] Problematic meshing of an inverted airfoil | snkutta | ANSYS Meshing & Geometry | 2 | October 11, 2011 13:23 |
