January 20, 2021, 09:12 |
BladeGen Meanpath Import Problems
Daniel
Rep Power: 9 |
Hello there,
I am working on a preliminary design tool in python for a centrifugal compressor. By now I was able to build a meanline model, generate a beta-angle distribution and transform the beta-angle into a theta-angle (wrap Angle) for 3D. To import my model I wrote a script to write the coordinate, theta and thickness data to the .rtzt-file format for Bladegen. When I import the file the first problem which occurs, is the cross over line (Figure 1). Usually Bladegen generates an Inlet- and Outlet Area but here this cross-over happens and I don't know why. Furthermore, when I correct the point at the shroud, the blade view won't generate anything good and a TE CutOff Error occurs (Figure 3). In Figure 2, you can see my theta-distribution and the recalculated beta-distribution by BladeGen. I also tried to only use a theta-angle of 0.0 at any point to see what happens. After importing, the cross-over problem occurs again. When I adjusted it the blade-view changes to figure 4. Which doesn't make sense at all. I can only imagine that my theta-values may cause somewhere a problem, although the problems still occur with a constant theta of 0.0. I rather would love to import my beta-data, so Bladegen can calculate the theta-distribution by itself although I used the given formular to calculate theta from beta. I'm very thankful for any advice! Thank you, Daniel |
January 27, 2021, 07:29 |
Daniel
Rep Power: 9 |
Answer for similar questions in the future:
1) The control curve cross happened, because one Point on my shroud curve had a negative value and was therefore offset to the other points. Only saw it looking at the point data more clearly. 2) The Error TE Cutoff happened, because I always imported my point data in meters. The .rtzt-File contains the radial coordinate, theta-angle, coorindate in Z-direction and the thickness. Because I exported my points in meter and my thickness was in millimeter, Bladegen couldn't generate my blades. So, I switched from meters to millimeters in my .rtzt-File and every problem was solved! |
[PyFoam] First discussion thread about PyFoam | braennstroem | OpenFOAM Community Contributions | 338 | March 17, 2022 14:05 |
[Workbench] DesignModeler & mechanical import | Mehdi41 | ANSYS Meshing & Geometry | 9 | August 1, 2016 11:04 |
Parallel computation problems with SU2 3.2 | akun646 | SU2 | 2 | July 19, 2014 12:04 |
[Commercial meshers] Ccm26tofoam problems | knabhishek | OpenFOAM Meshing & Mesh Conversion | 8 | April 15, 2014 08:37 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
