[ICEM] Meshing error -- mesh elements inside solid |
January 24, 2021, 04:59 |
Hui Zhang
Rep Power: 5 |
I tried to mesh the tutorial case elbow part, but when I generated mesh, why did I always have some mesh inside my solid part? can anybody help me? I am so confused. I have the midpoint SOLID in cylinder and FLUID point outside cylinder.[ATTACH]Capture1.PNG[/ATTACH]
Best, Hui |
January 24, 2021, 10:33 |
Kira
Rep Power: 8 |
My guess is that either you forgot the delete the block (as in Fig. 108, p.144), or your vertices are not associated correctly. |
January 24, 2021, 21:49 |
#3 | |
Hui Zhang
Rep Power: 5 |
I need to associate the block with my cylinder and then delete it. Now, I have successfully gotten what I want. Best, Hui |
January 24, 2021, 22:21 |
Kira
Rep Power: 8 |
Hello Hui,
Excellent, glad I could help and we were able to solve your problem. All the best in your endeavours with ICEM. |
icem; mesh; |
[ANSYS Meshing] Is there any way to reduce my meshing elements ? | miftahazhar | ANSYS Meshing & Geometry | 1 | July 22, 2019 03:04 |
Investigating the conductive heat flow INSIDE a solid | Mr.Tambourine | FLUENT | 4 | July 24, 2017 02:46 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[ICEM] Meshing Multi Solid Body for CFD | marauder | ANSYS Meshing & Geometry | 0 | March 18, 2015 06:32 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 04:32 |
