[ICEM] How to Coarsen Mesh in Selected Block
Like Tree3Likes
  • 1 Post By Ludvik
  • 1 Post By Ludvik
  • 1 Post By Ludvik
Old   January 24, 2021, 16:09
Question How to Coarsen Mesh in Selected Block
Kira
aero_head is on a distinguished road
Hello Everyone,
I am trying to coarsen the mesh in a selected block. The ICEM manual tells me I can:
Use Blocking > Pre-Mesh Params > Refinement to refine or coarsen the mesh. You can apply the refinement/coarsening in all three major directions simultaneously or in just one major direction.
Refinement
To refine the mesh, enter a scale factor greater than 1.
Coarsening
To coarsen the mesh, enter a scale
factor less than 1.
I go to the refinement option and enter a scale factor less than 1 (see screenshot where I used 0.5), but it gives me an error and tells me that the factor must be positive.
Am I missing something? Thanks in advance
aero_head is offline   Reply With Quote
Old   January 24, 2021, 16:15
Kira
I have found a solution.
I input 1/2 rather than 0.5 and it worked.
Edit: it seems to not like when I use a factor of 1/3 and gives me warnings as attached. What do they mean?
I am able to use 3X refinement in the opposite direction.
Last edited by aero_head; January 24, 2021 at 16:32. Reason: ran into another problem
Old   January 25, 2021, 05:59
Ludvik is on a distinguished road
That is just warning to hanging elements. Refinement "1/2" is for Fluent mesh. An "1/3" refinement is for CFX mesh. Look in Help on subsequent command "Edit Mesh > Merge Nodes > Merge Meshes".
aero_head likes this.
Ludvik is offline   Reply With Quote
Old   January 25, 2021, 11:13
Kira
Hello Ludvik,
Thanks for your reply.
I do intend to use the mesh in CFX. When I go through with the 1/3 refinement, the program actually closes on me, saying there is a segmentation violation. Would this still be due to the hanging nodes?
If I use 'Resolve Refinements', would that warning not appear?
Old   January 26, 2021, 01:45
The mesh refinement in Blocking really produce uncorrect mesh for CFX.
Switch Premesh to Unstructured Mesh and use tool "Merge Mesh, Method: Resolve Refinements" to solve this.
Old   January 26, 2021, 21:19
Kira
Could you please describe what you meant when you said the mesh it would produce would be incorrect?
Old   January 27, 2021, 04:04
Word "incorrect" isn't exact, better is "impractical". In a model are too many Mesh Interfaces, who consumes time for creating model, computational time, .. .
Old   January 27, 2021, 09:41
Kira
Hello Ludvik,
Thank you for the additional information/clarification
coarsen grid, icem, mesh, refinement
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
GeometricField -> mesh() Function Tobi OpenFOAM Programming & Development 10 November 19, 2020 11:33
[ICEM] Replay not working properly - Creating the mesh for Free Block. Wingman ANSYS Meshing & Geometry 4 January 17, 2017 03:57
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
