January 29, 2021, 13:16 |
CGNS mesh modification through ICEM
rbalmer
I am new to CFD and I'm looking to duplicate my mesh by mirroring about the x-axis. I am running simulations in SU2 which to my knowledge only supports .su2 and .cgns mesh files. I have a .cgns mesh file that I'm looking to modify in ICEM. I imported the .cgns file to ICEM where I have then mirrored the mesh, although I am not clear on how to export it back out as a CGNS file suited for SU2. I would appreciate some help on this matter which I appreciate is maybe quite trivial, I'm still learning my way through CFD. Many thanks Royce |
January 29, 2021, 14:03 |
Kira
Rep Power: 8 |
Hello Royce,
Select the 'Output Mesh' tab at the top -> select the 'Select Solver' option (it's the red toolbox) -> Output Solver (hit the drop down arrow): CGNS The go to Write Input (still in Output Mesh tab, last one on the right), select any scaling and/or other options and the click Done. Will save your file as a .cgns. |
January 31, 2021, 15:52 |
rbalmer
Thank you very much for your help!
cgns, export, icem, mesh, su2 |
[ICEM] CGNS Mesh Importation into ICEM | huey1080 | ANSYS Meshing & Geometry | 5 | April 3, 2022 18:19 |
Issues with CGNS formatted mesh in SU2 | jlwhelan28 | SU2 | 5 | February 13, 2017 11:48 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
