February 1, 2021, 06:16 |
Prism layer
vav noon
Rep Power: 6 |
Hello friends,
Can I apply finer tetra mesh around boundraies rather than prism layer in unstructured mesh in icem? Thank you |
February 1, 2021, 11:16 |
Kira
Rep Power: 8 |
Hello Vav,
Yes, you can. There is a tutorial in the manual called Tetra Mesh in a Piston/Valve Assembly. First Create Global Mesh parameters. Mesh > Global Mesh Setup > Global Mesh Size -Choose a Scale factor. -Choose a max element size -Enable Curvature/Proximity Based Refinement. Ensure the Min Size is set to 1. Next, Specify Volume Mesh parameters. Mesh > Global Mesh Setup > Volume Meshing Parameters -For Mesh Type, select Tetra/Mixed from the drop-down list. -Select your mesh method (Robust (Octree)) -Click Define thin cuts. The Thin cuts dialog box opens. Go from there. |
[snappyHexMesh] Prism layer collapsing in refinement transition | rubenparedes | OpenFOAM Meshing & Mesh Conversion | 8 | May 13, 2021 10:55 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 09:43 |
Questions about Polyhedral and Prism layer meshing | niablis | STAR-CCM+ | 3 | September 23, 2016 00:32 |
Trimmer & prism layer | peresah | STAR-CCM+ | 6 | October 6, 2009 14:39 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
