[ANSYS Meshing] Meshing Turbine inside Enclosure |
June 26, 2022, 13:38 |
Shehabeldeen
Rep Power: 4 |
Hello Guys ,
I'm working on a mesh analysis on a Savonius turbine which is inside two enclosures (Outer domain which is actually box ) and inner domain which ( cylindrical ) and the turbine is inside it the question here how to mesh the turbine itself as when i do meshing it meshes the cylindrical enclosure only and the turbine not meshed anyone can help thanks |
Turbine Meshing and Running | ashish.kumar | OpenFOAM Pre-Processing | 0 | May 29, 2017 05:02 |
[DesignModeler] Sweeping or surface meshing in enclosure? | Edu-R | ANSYS Meshing & Geometry | 9 | January 23, 2013 13:41 |
[Other] Problematic Geometry- meshing with enclosure. | lev1athan | ANSYS Meshing & Geometry | 2 | February 24, 2012 16:24 |
Meshing Volume in Gambit for a water turbine | Zaqie | FLUENT | 1 | July 24, 2009 01:25 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
