[DesignModeler] How to paste a line so that endpoints line up |
October 31, 2022, 13:41 |
Rep Power: 13 |
In design modeler, I want to copy a section of a curve, starting at the red circle, and paste it to make a continuous curve at the purple circle. I can copy the segments together as one cuve, but it seems I cannot get the pasted curve to match at the endpoint to form a continuous curve. How do I make sure they points overlap exactly? Please tell step-by-step to make this work.
Thanks |
parallel run error cma-permission-denied | supvato | OpenFOAM Running, Solving & CFD | 3 | October 10, 2022 04:48 |
Unknown function type pressureTools | Dorian1504 | OpenFOAM Post-Processing | 23 | May 25, 2021 09:24 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
